It is currently Sun May 18, 2025 6:41 pm
PostPosted: Mon Oct 31, 2005 6:37 am
I don't remember seeing any comments on this so thought I would ask.   I am wondering how most cover the soundhole when spraying finish to avoid overspray inside the guitar. I have tried several things like making a soft ball of newspaper, but haven't really been happy with that approach. I am spraying mostly McFadden's nitro. thanks! Tom H
PostPosted: Mon Oct 31, 2005 6:40 am
I use a ballon and a piece of card, blow up the Baloon inside the guitar and then use it to hold the card in place behind the sound hole. When you are done pop the balloon.
PostPosted: Mon Oct 31, 2005 6:45 am
I also use a ballon and cardboard.
PostPosted: Mon Oct 31, 2005 6:47 am
I had thought of a balloon, but thought the nitro might dissolve it, the card takes care of that doesn't it? Wow! other ideas?   thanks! Tom H
PostPosted: Mon Oct 31, 2005 6:52 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
nitro won't pop it or cause problems, but sanding will pop them so have a bag of them. I use now an old soundhole humidifier thing made up
PostPosted: Mon Oct 31, 2005 6:56 am
I use a large sponge and a potato salad lid works great.
PostPosted: Mon Oct 31, 2005 7:12 am
A lid from a cottage cheese container (or something like it) secured by a chunk of foam works great.
PostPosted: Mon Oct 31, 2005 7:21 am
balloon and a butter container lid
PostPosted: Mon Oct 31, 2005 7:22 am
Charlie Hoffman's site has a photo of a chip dip container held in place with a sponge from the bottom.
PostPosted: Mon Oct 31, 2005 7:24 am
I use good old masking tape.
I first line around the edges with the sticky side facing out,then finish with the sticky side facing down.
PostPosted: Mon Oct 31, 2005 8:23 am
Yeah ,like Brad said. I tried the balloon and thin cardboard but like the tape better. It's personal preference.
Never thought about a plastic lid. I learn something new everytime I visit the forum. It's great.
PostPosted: Mon Oct 31, 2005 9:17 am
I just blow up a balloon in the soundhole. No card. It works fine.
Sylvan
http://www.wellsguitars.com
PostPosted: Mon Oct 31, 2005 9:29 am
   I do like martin and use a 1/2 pint deli cup and a block of foam. The nice thing with this set up is you can set a card between the cup and top to get an idea on how much lacquer you spray.
john
PostPosted: Mon Oct 31, 2005 10:31 am
Thank you all for the replies.   I'm ready with my balloons now! Tom
PostPosted: Mon Oct 31, 2005 2:32 pm
Like Sylvan, I just use a baloon by itself. It leaves the smallest little lip of lacquer build-up right at the edge of the hole, but that trims off easily once the baloon is popped.
Users browsing this forum: Bing [Bot] and 30 guests
